Get list of devices and interfaces in LabView2024
Hello
I start using LabView2024, and i want to check list of RIO cards in PC. In LV2019 I checked it with VISA Find Resource. In 2024 version i didn't get list. In NI MAX I see devices.
(153 Views)
Can you share the regular expression used for this Query? Is it INSTR ?
Mano Prabha
(127 Views)
I left it blank. I attached snip with 2024 version and 2019 version. Rio Card is PCIe-7841R which is not supported in LabView FPGA 2024 version, however I can use card in 2024 with bit file from LabView FPGA 2019 version.
(105 Views)
Got it. Can you try with the ?*INSTR regular expression?
Mano Prabha
(75 Views)
The result is the same. Rio Card not found.
(68 Views)
y answer is surprisingly similar to another post I responded to earlier.  In NI-MAX, under Tools --> Ni-VISA --> General Settings --> Passports  you will find Passport plugin for NI-RIO.  Enable it.  (On my system it says 32-bit only, so YMMV.)
Bill
CLD
(Mid-Level minion.)
(54 Views)
Try NI System Configuration API instead.
In LabVIEW Example Finder, go Hardware Input and Output >> System Configuration >> Find All Hardware.vi
Add an "expert" filter and wire "ni-rio" to it. Valid Experts for the System Configuration API Functions
(20 Views)
