Get one sample every 5th second
I am trying to save every 5th continuous rms value in an array. I tried some loop method, but it shows me the value and afterwards it shows zero then next value. Is there any gate that will give me data, only if the condition is true?
(962 Views)
Hi mub,
Use a conditional output tunnel on your loop: set to TRUE each 5th iteration…
When the data already come in an array: use the DecimateArray function…
Generic advice: Always provide an example VI to explain your problem! Which kind of data are you working with? What is the expected result? Why are there "zero" values in your array?
(955 Views)
Didn't upload, because my program looks stupid. The condition was inside the loop, so when true I was getting the values, but when negative it was sending zero. I put the loop now inside the condition. It still looks weird, but working. I couldn't exactly get your suggestion. Could you elaborate please?
(944 Views)
Accepted by topic author mub.re
Hi mub,
Please read the LabVIEW help on loop tunnels and their different operation modes/options. One of them is called "conditional tunnel"…
Which is perfectly ok once you "THINK DATAFLOW!"
When there is an output on a case structure then there has to be an output value for each case…
(932 Views)
