07-28-2017 12:32 PM
All,
I am trying to recreate the VBA code here in LabVIEW '16 to tell me what the last row is without hard-coding anything (like the cell address). Right now, I am calling a VBA function that tells me what the last row is in a particular column (A).
Sub LastRowInOneColumn()
'Find the last used row in a Column: column A in this example
Dim LastRow As Long
With ActiveSheet
LastRow = .Cells(.Rows.Count, "A").End(xlUp).Row
End With
MsgBox LastRow
End Sub
When I try to recreate the code in LabVIEW, I don't see the optional parameters for the Cell object that you get when you code this with VBA. I am sure it is something that I am missing but maybe I just need another set of eyes to look at it. You'll see that I have tried to use the Range object, but that only results in an error. Any ideas?
07-28-2017 01:35 PM
Why not use the built-in function, Excel Get Last Row?
07-28-2017 01:52 PM
I had forgotten about that. Thank you.
