Graph is not correct in another PC which have window 11 and microsoft version 365.
Accepted by Poojaavi123
Check the OS accessabiliy settings.  I would suspect one PC has a monitor resolution of 100% and another is set to the default 125% or 150%  since LabVIEW graphics are not vector based those settings are not recognized.
"Should be" isn't "Is" -Jay
Message 11 of 16
(584 Views)
Resolution is same of all PC it is 100%. I am not able to understand why this is happening for Same exe.
Message 12 of 16
(558 Views)
Please help on above topic , This issue is pending and I need to resolve this issue.
Why this is happening if same exe I am using in all PC. Is this window compatibility issue with LabVIEW?
Message 13 of 16
(537 Views)
Why do you think it is a LabVIEW problem ?
Could it be a Excel problem ?
A problem with how you have programmed your exe ?
How do you think we should be able to help you ?
Do we have your code ?
Do we have your excel files ?
Message 14 of 16
(520 Views)
I would suspect Office being the issue here, try to make it the same version of MS Office on both machines.
Santhosh
Soliton Technologies
Message 15 of 16
(517 Views)
Thanks for your response.
Now Problem is resolved . I Tested on LabVIEW version 2023 and Change resolution 125% to 100%.
Message 16 of 16
(504 Views)
