Graphing a Single Channel of a MultiChannel DAQ
I have an NI4472 4 channel daq card with channels 0,1,2 connected to a vibration sensor and channel 3 connected to a microphone.  I want the 1st 3 channels on one fft plot and the 4th channel on a separate fft plot.  My question is how do I separate the channels route them to a particular graph.  I'm using roughly the attached code daq assistant, spectral measurement and graph is the attached .vi.   Is it not possible with this block of code?  Thanks in advance.
(2,595 Views)
Easiest way should the use of "Split Signals" and "Merge Signals".
Regards, Guenter
Message Edited by Guenter Mueller on 09-15-2007 11:16 PM
(2,593 Views)
Gunter;
Thanks for help.  I'll give it a try 1st thing this morning.  Much appreciated. -- Kurt
(2,536 Views)
Worked well.
(2,524 Views)
