HEX Strings change to Octal
The string which show as Hex, I want to change it to Octal data.
How to do it?
(3,139 Views)
You need to cast it to numeric and then format it into string using %o format or similar. Is the string always exactly 4 bytes?
(3,131 Views)
Exactly 3 bytes. Can you give me a vi sample ?
(3,125 Views)
Accepted by topic author orlando111
I find way to improve it.
Do you have another way?
(3,119 Views)
That will work, but your numeric array is being displayed as hexadecimal not octal like you asked.  You can change it to Octal using the dispaly format dialog.
(3,102 Views)
you can change the properties .
(3,096 Views)
