HOW TO WRITE KBC PROGRAMME ?
How to write KBC Programme in LabVIEW ?
(669 Views)
What is KBC Programme?
Do you need to call a function developed in another IDE?
Clarifying your requirement in detail will help others to understand better.
(662 Views)
  1. Start with a new VI.
  2. Look at your documentation to see what a KBC program does (we have no idea, because you did not define it)!
  3. Create the require inputs as controls and the desired outputs as indicators.
  4. Implement all the UI handling, math, and logic on the diagram
  5. Save the VI as KBC.vi.
  6. Build it into a standalone application if desired.
Once you tell us in more details what KBC is (there are so many possibilities!!) we can potentially give more specific advice.
LabVIEW is a very rich programming language, so anything can be done given the right skills!
(605 Views)
Guess, the OP might be referring to an Indian TV Programme called 'Kaun Banega Crorepati', the Indian version of 'Who wants to be a millionaire?'
Santhosh
Soliton Technologies
(601 Views)
