HTTP POST "Response body" incomplete content
The request is a regular HTTP POST using JSON. Running the code returns with status 200 OK but the responce body is completely different.
Expected Responce body: The call was successfull! JSON-String = <Request JSON-String>
Somehow the responce header Content-Type: text/html; charset=utf-8 eventhough it was assigned to "applicaion/json".
Executing with POSTMAN or c# with same settings returns the expected responce. See images in attachments.
Am i doing something wrong or some settings in LabVIEW webserver needs to be configured.
I tried to recreate the code using .net but was unsuccesfull.
(2,687 Views)
Accepted by topic author nik35324
This is on the server implementation and not much we can help with from the LV side with the info you have. You'll want to use wireshark to capture and compare the requests being made between postman and LV; I suspect there's some other headers or formatting that's causing the difference but knowing what to "fix" would depend on knowing what the server is doing.
~ G stands for Fun ~
Helping pave the path to long-term living and thriving in space.
(2,653 Views)
Thank you very much for suggesting sniffing tool Wireshark. Issue has been resolved.
Passed empty string to input Path
(2,625 Views)
Then I lied, a screenshot of the code probably would have solved this too 😉
(2,608 Views)
