Handling multiple clusters with insert data VI
Hi all!
I'm very new to labview and i'm trying to handle multiple clusters with different value types, writing them using the insert data VI into my database table this way:
But i'm missing something because i'm getting this error
i'm sure the number of columns and parameters are correct because before this FOR loop i had separate subVI insert data for each bundle but i wanted to simplified the architecture for more inputs.
Can you guys help me?
Thank you so much
(249 Views)
You might need to change your column names.  Some of those may be reserved keywords.
aputman
(236 Views)
Accepted by topic author Jojoee
Look really close at your data.  You're not passing in a cluster of 3 elements, you're passing in a cluster of 1 element containing a cluster of 3 elements:
Replace the "build cluster array" node with just a "build array" instead, and that should do it.
(200 Views)
That was it! I thought the cluster array was the uculprit but i didn't know how to fix it.
Thanks a lot!
(183 Views)
