Hardware configuration with PXI
I need to control the operation of a chemical pump using the Labview.
The control panel consist of:
1. Pump, on/off
2. Two Heaters on/off
3. Tank level indicator, sensys co.
4. pressure transmitter, sensys co.
5. vibration transmitter, sensys co.
Its first time for me. What are the parameters I should check on? What other hardware I will require?
(2,300 Views)
Hey,
You should call your local NI office to discuss the whole system setup per phone. That's easier.
Christian
(2,290 Views)
As Christian said, the best method of obtaining the correct hardware/software that you will need for this application is through our customer service center. I would recommend having the specifications or data sheets of the sensors that you are using available to allow the customer service representative to better assist you.  Also you will need to know the power requirements to turn the pump and heaters on/off.  There are simply too many specifics that need to be addressed to try and assist over discussion forums.
Thank you,
Justin
Justin
Product Support Engineer - Conditioned Measurements
(2,276 Views)
