I have to read values from a text file, locate specific ones and write them to file again. I have been trying to creatre the attached vi for the task. It will read in the values I need but when I read in the file a second time, I loose some data on the concatonated lines.
Please see the attached and use the HSFACTOR.txt file as the sample. (You might want to make backups of it).
I appreciate any suggestions on what I can do to make the task easier.
