07-06-2016 02:29 AM
As I am working on LAbview and I am getting some problems related to it. Some of the blocks are not in library, which are marked with black circle in the attachment. Simply I have to estimate the phasors with the help of recursive and non-recursive algorithm in LABVIEW in the attached file, nonrecursive algorithm have been used where,A 50-Hz signal x(t)=230 cos (120*pi*t+pi/4) is sampled at a frequency of 600 Hz i.e. 12 samples per cycle are taken. First 20 samples are obtained and phasor estimate through recursive and nonrecursive are evaluated. The data window is of 12 samples. Since phasor estimation is performed over a cycle, the first phasor is obtained after obtaining 12 samples i.e. after one complete cycle of the sinusoid. The phasor output in polar form for recursive and nonrecursive estimates as obtained from Labview front panel as shown in attachment.
The input signal can be generated from library VI i.e. Simulate Signal VI. This signal can also be real time acquired from a data acquisition system like NI ELVIS which is compliant with Labview. This analog input signal is then converted to discrete signal with A2D VI and stored in an array. Here data window is considered for 12 samples. A user defined VI has to be prepared for calculating the Fourier coefficient of the data samples. Appropriate arithmetic operations are performed to estimate phasor for first data window. The complex term obtained after phasor calculation is converted into polar form and displayed as output. This algorithm is repeated for subsequent data samples.
07-06-2016 02:26 AM
07-06-2016 02:52 AM
07-06-2016 03:57 AM
This is the attachment
07-06-2016 04:34 AM
08-10-2016 02:05 PM
Hello sir..
Sir in this I am getting magnitude with angle but i am getting only 1 value. I am not getting the same magnitude and angle should be progressed by 30 degree. Magnitude is shown in block (array of clusters) coming 162.635 with the angle 45 degree but i am not getting all values
not getting this
162.635∠45°
162.635∠75°
162.635∠105°
162.635∠135°
162.635∠165°
162.635∠-165°
162.635∠-135°
162.635∠-105°
only getting single first value
and i also want to know the time taken to find out the non-recursive updates as shown in block array of clusters.
08-10-2016 05:00 PM - edited 08-10-2016 05:01 PM
If you talk about mangitude, angle, value, etc. it would help to change the label of the various controls so they correspond to the meaning.
In any case, your express VI is configured to reset with every call. Configure it for "continous generation" instead and also slow down the loop rate so you can actually see what's happening.
08-10-2016 11:14 PM
Respected sir,
But I want to see the results with each and every value. I want individual Ans like this.
162.635∠45°
162.635∠75°
162.635∠105°
162.635∠135°
162.635∠165°
162.635∠-165°
162.635∠-135°
162.635∠-105°
So please tell me how will I can get these values, So that each of these values are visible.
08-10-2016 11:20 PM
I am getting only three values i.e.
162.635∠45°
162.635∠-75°
162.635∠-165°
these are wrong. I need these values
162.635∠45°
162.635∠75°
162.635∠105°
162.635∠135°
162.635∠165°
162.635∠-165°
162.635∠-135°
162.635∠-105°
08-11-2016 12:22 AM - edited 08-11-2016 12:25 AM
If you need different values for the incremental phase, you need to change the parameters of the signal. Figure it out: The starting phase of the next wave is wherever the previous wave ended, so the fractional part of the period is important.
You've been working on this now for weeks making basically no progress. Just do the math and the rest will fall into place. It seems you want a 30 degree increment, so each single wave should be N+1/12 periods.
