Help with Reading, Charting and Saving multiple analog and digital signals
Hi all,
I am looking for some help with reading multiple analog and digital signals. Once read, I would like to chart and save the data for later analysis.
I have a working version for one analog and one digital signal (Analog and Digital - Working.VI).
The problem starts when I add a second digital channel as per 'Analog and Digital - Not-Working.VI. I get the error 201105 and can only chart and save data from the analog signal and one digital signal. I have tried several alternative metods such as reading two channels  using one 'DAQmx Create Channel' which stacks up the digital signals. As I want them seperate, I have tried to convert them into a bolean array and then indexing the array to split the signals but this fails to record either of the digital data (Both Digital Signals though One DAQmx.vi).
I have attached the working VI with one analog and one digital signal and the non-working VI with and additional digital signal.
Any help or adivice would be appreciated!
(3,202 Views)
I only opened the "Both Digital Signals through One DAQmx.vi". So my comments for this VI:
  • You specify two channels for the Digital part, but you use the Polymorphic 1Chan NSamp. If you specified two channels, use the NChan NSamp version of the DAQmx Read function
  • You do several data transformation on the results in the while loop, it looks strange to me what you do, you could just save simply the waveforms, no?
  • I would not use File logging Express VI specially in a data acquisition loop, it decreases performance.
  • For such cases, I always use a proper Producer/Consumer pattern. Only perform the two DAQmx Read tasks in the While loop, and Enqueue the results into a queue. Then after Dequeue-ing the data in the Consumer while loop, you can work on this data without "disturbing" the DAQ in the top Producer loop. I would use TDMS low level file functions to save the results into a file in the Consumer loop.
edit: You should also use two DAQmx Clear Task functions after the loop to properly release the HW resources.
Edit2: when you specify the DAQmx Read function as "NChan NSamp", then you also need to tell the driver to use two channels for the two lines:
(3,175 Views)
The VI below (snippet: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2PkCAI&l=en-US ) can give you some idea how to create a Producer/consumer pattern. Finish the data logging part, if you get problems with that part, post your actual VI and we can help and advice.
(3,167 Views)
Thanks Blokk for reviewing my VI and making some suggestions on how to make it work.
I will try and complete the design and see if I can make it work. I will let you know how I get on.
(3,143 Views)
