Help with name (string) to number (numeric) program
I need to make a program where I can write a number on a numeric control and it will be displayed the name of the number on a string indicator.
example:
Write: 10, or 20, etc
See: Ten, or Twenty ,etc
And on the other hand write in words the number on a string controller, and display the number on a numeric indicator.
example.
Write: Ten, or Twenty ,etc
See: 10, or 20 ,etc
Thanks for the help, greetings!
(2,847 Views)
Hi Jorquev,
I suggest to setup a dictionary of all the words you want to support (how big can those numbers grow?). Then use some algorithm to convert the numeric value into strings picked from your dictionary…
This basically works the same: look for the input words in your dictionary to convert them back to numeric values.
What have you tried so far?
Where are you stuck?
This is a great job to learn basic LabVIEW programming: is this some kind of homework?
(2,832 Views)
There's an app for [half of] that!  Install the OpenG string library from VIPM.
Jim
(2,801 Views)
Spoiler
I hope it's not homework.  Jim gave him the answer.  Smiley Wink
aputman
Heads up! NI has moved LabVIEW to a mandatory SaaS subscription policy, along with a big price increase. Make your voice heard.
(2,780 Views)
