Help with using "Save to Series of Files (multiple files)"
My name is Daniel R.
I am a student doing undergraduate research and was put on a project using LabView (having no previous experience using Labview).
I am using LabView 2013 Student Edition version 13.0.
Now the VI I created is to obtain data from a PMT using a Rigol DS1204B connected to Labview.
The problem that arose was saving to a series of files (automatically saving). I plan to take at least 1000 runs and manually naming each is not very efficient. I have my VI attached, if anyone would kindly take a look at it. I suspect the problem is coming from the "Write to Measurement File" in the block diagram. I have set the "Save to series of Files" option, however, when I double click the "Write to measurement" box I see that "Save to one File" is chosen and after a second it converts automatically to the "Save to Series" option.
I do not have enough experience to properly know why it wants me to name each file, so I am reaching out for help.
Any advice or improvements on my VI is also appreciated.
Thank You,
Daniel R.
(2,987 Views)
It is the Write Waveform to Spreadsheet File that is causing the dialog boxes.  You need to supply a file path for it.
GCentral
(2,964 Views)
Ok, I did that and now it writes a file automatically. However, anyother signal wants to replace the current file (I do not want to append the file, but make new files automatically)... do I have to connect it to the "Write to Measurement File"?
Ive tried connecting it with no luck.
Thank you for a quick response,
Daniel R.
(2,955 Views)
Accepted by bigoldfrog
Who says you can't dynamically build a file name each loop iteration?  I like to use the Format String to add the loop counter to a string that then is turned into a file path.
GCentral
(2,949 Views)
Thanks, that worked perfectly.
(2,936 Views)
