Hex & Reading board VI
forget how bothersome linking VI's is!!
Message 11 of 18
(895 Views)
Zip all the VIs and attach one file.
Lynn
Message 12 of 18
(890 Views)
Accepted by topic author dhanna
Hi dhanna,
in your array you defined a HEX number like "6065710800000699" in an I64 array.
In your connect.vi you defined an I32 number which CANNOT hold that number. Thus it gets coerced to I32-MAX of 0x7FFF.FFFF…
Always use the correct datatype. Create constants by right-clicking the corresponding terminal…
Message 13 of 18
(887 Views)
think whats needed is now there?
Message 14 of 18
(885 Views)
Hi dhanna,
yes, it's all there.
You need to learn how to use those different datatypes and after that change the datatype of your numeric constant!
Message 15 of 18
(876 Views)
shouldnt matter about the representations as all i've done is change the original array to have that new hex code (which represents a different board) in. as opposed one of the boards it had (606578000000000E)
Message 16 of 18
(876 Views)
Hi dhanna,
I can't comment on what you changed and what you didn't changed.
All I see is a coercion dot and a datatype mismatch!
I suggested a possible solution. You might look for other solutions if mine is no option for you…
Message 17 of 18
(871 Views)
got it!! one of the data types had to be 64, so kudos!!
the other mistake was i mistyped a number into my Hex code........ 😞
thanks guys, shall give kudos for our help
Message 18 of 18
(856 Views)
