How To Add Items To VI Server Reference Shortcut Menu
I'm trying to add items from the drop-down list of the VI Server Reference as shown in the snapshot below.
(579 Views)
Hi Sameer,
Your request is confusing. In the title you say "add items TO the shortcut menu", but in the description you say "add items FROM the drop-down list".
"Add item from the drop-down list":
Just drop a new "VI Server Reference" node on your diagram and select the item you want from the drop-down menu.
"Add item to the drop-down list":
The drop-down menu of "VI Server Reference" only displays controls that are currently present on your Front Panel, so you first need to add your new control to the Front Panel.
Raphaël.
(564 Views)
That's not too clear, but it might be simple.
Copy those references, and change them to the new objects.
Or select the terminals of the objects, and select Create>Reference.
Or select the controls, and select Create>Reference.
You will have to wire the new references to the Build Array.
(547 Views)
