How can I display a avi-file while acquiring data from a DAQ-CARD at the same time
While my system is acquiring analog data and controlling a motor, I want to display a avi-film (preferably in full-screen, so that the LabView GUI disapears during this process). Are there any VI's to open external players? May I face some problems to lose samples, due to the calling of external players?
(2,853 Views)
An example that uses the Windows Media Player can be found here.
(2,852 Views)
I've already found this example, but it doesn't work with the latest media-player. Anyhow, thank you for your answer!
(2,852 Views)
If you can't use the previous edition of the player, you might try an ActiveX control if there is one available for playing *.avi files. Also, if the player takes up a lot of CPU power, you may see your data acquisition slow down, but you should not see any samples lost.
I hope this helps!
Liz Fausak
(2,852 Views)
mhi wrote in message news:<506500000005000000F4280100-1042324653000@exchange.ni.com>...
you can also try out this free vi from my website:
http://www.geocities.com/irene_he/FunStuff.html
Irene
(2,852 Views)
