How can I inverse the Split 1D Array by recombining the splitting array?
How can I inverse the Split 1D Array by recombining the splitting array? i.e I have two boolean arrays A and B, and I want them in one boolean array: A array elements followed by B elements (NOT Interleaving)
Thank you
Message 1 of 10
(4,091 Views)
Hello ysma,
You can use the "Build Array" function from the Array pallet. The function has two option to connect the inputs. One makes a 2D Array out of the inputs an the other one connects the inputs and it is still an 1D Array.
I hope that helps you.
Message 2 of 10
(4,082 Views)
This input mode is switched by right clicking the Build Array primitive, right clicking, and selecting Concatenate Inputs:
CLA
Message 3 of 10
(4,075 Views)
What I want to do is making encapsulation for a random packet (group of logic bits ones annd zeros) like a network packet by entering my data with IP address, both are in decimal numbers, then I turned both of them to a boolean array, after that I want to make a packet datagram by putting IP data as a header followed by my data.
When I did this, Build Array added just first bit for both entries, and when I marked on Concantenate Inputs, it added ony the first array.
It can be done easily by decimal numbers, but boolean? Did I miss something?
See attached vi file
Message 4 of 10
(4,026 Views)
Hi ysma,
can't open your VI so a basic example on concatenating arrayshas to do:
Message 5 of 10
(4,017 Views)
If you want the appearance of concatenating Boolean arrays in the manner that you describe, I believe you can also logical shift the numeric value for array B and then adding the numeric values of A and B together. Something similar to this:
CLA
Message 6 of 10
(4,013 Views)
Also, on second thoughts, if you're converting a number to a Boolean array, the resultant array is either 8, 16, 32 or 64 elements long depending on the numeric being converted.
So if you're concatenating A (32-bit integer to Boolean array) to B (32-bit integer to Boolean array) it may take some scrolling through elements to see the elements from array B 🙂
CLA
Message 7 of 10
(4,008 Views)
Thank you Marcus_Körner ,
Message 8 of 10
(4,005 Views)
Accepted by ysma
Hi ysma,
- you cannot convert SGL data directly to boolean array as the red CoercionDot is showing you...
- you still don't concatenate the arrays (despite all the comments in this thread) but instead create a 2D array...
Try this:
Message 9 of 10
(4,000 Views)
Thank all of you indeed
Message 10 of 10
(3,990 Views)
