How can I make an adaptive Y axis on a waveform graph?
Hi all.
I am plotting very small relative pressure changes on a waveform graph and want a fixed range Y axis (say plus or minus 50). However, the measurements are affected by atmospheric pressure so the absolute level changes from day to day, one day it could be that the axis needs to be 100 to 200, the next day it might be 600 to 700.
In this example, I don't want an axis that goes from 0 to 800, you wouldn't see the small relative measurements. Nor do I want an autoscaling Y axis that jumps about and fills the screen with signal.
What I would like to do is to adapt the scale so that it is, say, 50 above and 50 below the mean of the signal over a short period. The operator could adjust the scale manually but I would like to do it programmatically.
I have tried to simulate the sort of signal in the enclosed vi. The actual code needs the hardware to produce anything.
Thanks for any help.
Andrew
(2,981 Views)
Accepted by topic author ASH2020
Hi Ash,
Determine the needed range programmatically (as you already seem to know the required algorithm) and set the Y axis min/max using property nodes!
(2,964 Views)
Thanks for that. I don't know why I didn't think of it. I've tried it and it works nicely, by averaging the dataset that I'm plotting. I just want to set the scale when the vi is run for the first time but it is adapting with each dataset coming in. I suppose I could set a one time flag and put the bit of code in a case loop?
(2,949 Views)
Hi Ash,
LabVIEW has a FirstCall function…
(2,945 Views)
You might want to add a button to rescale the axis on demand as well.  So it would be First Call? OR Rescale to do the analysis and set the scale.
GCentral
(2,927 Views)
That's a great idea. I will do a button. Thanks.
(2,916 Views)
@GerdW wrote:
Hi Ash,
I didn't realise that. Perfect for this issue. Thanks.
(2,913 Views)
