08-28-2016 12:36 AM
when I use a PID.Vi to adjust a pressure, when the PV close to SV, I want the PID.vi hold its output,but I have no idea to set the deadband parameters! (can not find how to set dead band )
A PLC engineer said that deadband is a common PID parameters ,but Idon't know how to set it in labview pid !
Help ,please,thanks!
08-28-2016 09:08 AM
You already wrote what you have to do. One possible implementation is simply "freezing" the output of the PID controller. Use the "advanced" version of the PID VIs (either the normal or the one with autotuning if you need it).
08-30-2016 09:06 AM
