How can I use the LabVIEW Symbol Editor as a Sub-VI?
Message 1 of 8
(2,952 Views)
What is the LabVIEW Symbol editor?
Message 2 of 8
(2,952 Views)
In LabVIEW 7.0, the window from the Icon-Editor from National Instruments is caled "Symbol-Editor".
The "Symbol-Editor" is used to make or modify Vi-Icons, Icons from Globals, Icons for Controls etc..
The "Symbol-Editor" opens, is you make a double-click on the vi-icon on the front panel.
Message 3 of 8
(2,952 Views)
It looks like someone else that was poking around in th basement found an interesting gem!
Please share where you found this VI.
Try dropping the icon on the diagram of a new VI and check out the help (:))).
The icon connector may help give you some clues.
But...
what does it return?
Ben
Message 4 of 8
(2,952 Views)
The problem is, that I have not found the vi yet...
Of course I know how to put the vi into the diagram etc...
Message 5 of 8
(2,952 Views)
You can't find such a VI because it doesn't exist. The
Icon Editor is a built in window in LabVIEW and not a VI.
Rolf Kalbermatter
Rolf Kalbermatter
My Blog
Message 6 of 8
(2,952 Views)
Thank you for your ansver.
That means that you see no possibiltiy to use the built in window? (I think the built in window is programmed with LabVIEW as well...)
Message 7 of 8
(2,952 Views)
The icon editor at least up to version 7.0 of LabVIEW is not written as
VI but directly implemented inside LabVIEW, which is written in C/C++.
Rolf Kalbermatter
Rolf Kalbermatter
My Blog
Message 8 of 8
(2,952 Views)
