How can the K-Nearest Neighbor of MLT be implemented?
k-NN of MLT has distance.vi as input. From where can i get this vi. I am not able to understand in what format the other inputs (examples, class labels, new sample, k) are applied. Please guide me for the same. I have searched a lot but couldn't find the solution.
I have downloaded the machine learning add-on from internet. It is working but unlike other installed components, detailed help is not available for MLT components.
Thanks & best regards !!
(3,474 Views)
Accepted by akanksha91
https://decibel.ni.com/content/docs/DOC-19328
maybe that helps
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(3,452 Views)
Thankyou sir for the prompt reply.
I have already read this document as suggested in earlier threads of k-NN. But this document provides merely the basic understanding of learning algorithms. It doen't contain any knowledge of how to connect.....that is essentially required. Some examples are also given but those examples also don't include k-NN. Manual installation file has K-Nearest Neighbor.vi. This vi also has the same distance block. Kindly advise about the usage of distance block/vi and any example if possible.
(3,438 Views)
unfortunately i can not.
(3,432 Views)
No problem sir.
Can i know the functioning of distance.vi so that we can design our own VI for the same function, to proceed further with k-NN MLT. Please someone suggest me in this issue. I need it urgently.
(3,417 Views)
