How do I create a periodic task (T = 30 mins) and still have the interface responsive?
Hi.
I created an application that drives a stepper following a certain rule every few minutes. The problem is I cannot stop the program before it finishes since the respective iteration still needs the delay to timeout.
I used two approaches, namely a "Wait" block  and a Timeout included in a case structure. Either way, I had to wait for the time interval to pass in order to press the "Stop" button.
Is there an easy way to fire a periodic task (or alarm)?
Thanks.
(3,077 Views)
It would be good if you can show the code what you have done as a snippet ot the vi (2009 version please)
(3,074 Views)
Thanks for your reply.
Can you give me some pointers regarding alternative methods to the two that I already wrote about? I'd like to try them first and then I'll post my code. I do this mostly because my script is very "spaghetti"-like and cleaning it up will take me some time.
All that I need is just the principle of the method no matter how generic it is.
(3,071 Views)
Accepted by anarchix
Why don't you use the Elapsed Time function?
(3,067 Views)
Already tried it. I must have set the wrong paramaters because I never got it working. My stepper is suppose to finish doing its thing in max 15 secs. I suspect that I set the wrong interval in the block and mistakenly assumed that the secquence was never executed -> my mistake was that for testing purposes I set the Elapsed Time interval to 10-30 seconds to make the tests faster.
I'll post un update as soon as I'll test my code.
Thanks a lot.
(3,063 Views)
What is the delay time you are giving?
(3,061 Views)
It seems that I wasn't running Elapsed Time in a loop. Now everything runs fine.
Thank you.
(3,031 Views)
