How do I creater a indicator to read power factor
The problem that I have is not that I can read power factor because our RTU gives me a analog input in numeric fomat for our power factor. I need to know if there is some sort of scaling or indicator ( such as a analog dial type gauge) that can be scaled to read power factor in the below format. We want to see Lag / Lead that mimics our mechanical analog meter at the power plant. Any suggestions?
-0.5
-0.6
-0.7
-0.8
-0.9
1.0
0.9
0.8
0.7
0.6
0.5
Message 1 of 9
(3,614 Views)
Why not just use the dial or guage in the Numeric Controls palette?  You can change the scales easily enough to be a -1 to +1.
GCentral
Message 2 of 9
(3,604 Views)
You can certainly use a gage or meter to display the values that you state. What specifically is your problem? How often do you get a new value?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 9
(3,601 Views)
I have exactly the same problem. How to do it? If you create a scale with a minimum and a maximum value of -0.5 + 0.5, in the center of the scale is 0 instead of 1 as it should be...
Message 4 of 9
(3,393 Views)
The center of the range -0.5 to +0.5 IS zero. I don't know why you think differently.
Message 5 of 9
(3,383 Views)
I think he wants to make a LabVIEW version of the real-life meter seen here:
http://www.alibaba.com/product-detail/BE-96-96-96-Power-Factor_1707875502/showimage.html
I don't know how you'd do that with any sort of standard control, though...
Message 6 of 9
(3,378 Views)
I would like to use meter with scale as show in post #1 . That's why I would like to see in the center 1 NOT 0
Message 7 of 9
(3,367 Views)
It should look something like this. I used a text label for scale markers.
text labes    Value
-0.5                0
-0.6                1
-0.7                2
-0.8                3
-0.9                4
1                    5
0.9                 6
0.8                 7
0.7                 8
0.6                 9
0.5                 10
But how to convert  1 +/- 0.5  -->>  0 to 10 I don't know...
Message 8 of 9
(3,339 Views)
Solved. Thanks to everyone
Message 9 of 9
(3,323 Views)
