How do I have LabView run an exe file?
I am trying to get LV8 to run an .exe file on my computer. (WinXP). See the attatched .jpg. What am I doing wrong?
Help.... Smiley Wink
-Christian
Message Edited by Christian_nor on 06-21-2006 03:18 AM
Message 11 of 16
(1,995 Views)
It looks like you may just have a syntax error.  See my post in the following thread which discusses a simple example which launches notepad.exe:
I think this will set you in the right direction!
Best Regards,
JLS
Best,
JLS
Sixclear
Message 12 of 16
(1,972 Views)
USED BELOW COMMAND FOR RUN EXE USING LABVIEW.
cmd/ k(folled by exe adreess).
example:-cmd /k"D:\PROJECTS\builds\CMD\My Application\Application.exe"
Give this command to a system exec VI and click on run. it will run the exe.
Message 13 of 16
(837 Views)
You realize you revived a thread that was 20 years ago started and had it’s last activity 15 years ago?
Rolf Kalbermatter
My Blog
Message 14 of 16
(828 Views)
Yupsss I thought we can reply to the tread which started 20 years before .....😉...next time I will check
Message 15 of 16
(800 Views)
No one is going to whip you for responding to an old thread. 😀 The usefulness is however often questionable.
As your response was a solution it might be helpful for future readers but it wasn’t fundamentally different to earlier solutions already posted in the thread.
Rolf Kalbermatter
My Blog
Message 16 of 16
(794 Views)
