How do I include all the necessary files required for the DAQ Assistant to create an executable file?
I am creating an executable file to run on a computer that does not have LabVIEW installed.  The problem is that I am using the DAQ Assistant.  The VI Hierarchy is rather large, and I am not sure how to include all of the required files to eliminate the error "The full development version of LabVIEw is required to fix the errors."  Attached is an image of the VI Hierarchy.
Message 1 of 9
(3,416 Views)
Did you create an installer and with the installer include DAQmx, MAX, and the hardware configuration from MAX?
As long as you see all the subVIs in the dependencies list of the project, you don't have to do anything else when building the exe.
Message 2 of 9
(3,412 Views)
When this is all I do I get an error that subvi is not included, a list of about 6 subvi's.  To eliminate this error I manually add the subvi from the dependencies list to the my computer list. This allows me to add them as support files.  This eliminates the error about subvi not included, but then I get the error I spoke of earlier.
Not sure what MAX refers to?
Message 3 of 9
(3,403 Views)
Including traditional DAQ is a waste of time and you must install DAQmx. That is the driver for the 6009. Manually install if you must from your distribution DVD/CD.
MAX is Measurement & Automation Explorer and you probably need to export the hardware config and then import it on the new pc.
Message 4 of 9
(3,394 Views)
During my installation i received several errors.  Not sure what path is missing.
Message 5 of 9
(3,378 Views)
Can't tell from the image what path you specified. If you suspect the DVD is damaged, you can download it.
Message 6 of 9
(3,370 Views)
Accepted by Miked1227
I do believe I am missing something in the installation.  I am downloading the DAQmx now.  I knowticed that all 7 of my missing subVI are DAQmx****.vi
Message 7 of 9
(3,358 Views)
Mike,
Let us know if that fixed the issue for you.
Justin Parker
Product Support Engineer
Message 8 of 9
(3,318 Views)
Ok, so I downloaded DAQmx 9.1 and installed.  I then recreated my installer with no errors.  I installed on the target computer and all is well.  Thanks alot for the help.
Message 9 of 9
(3,293 Views)
