How do I separately extract the amplitude and frequency data from a signal?
I have been trying tbob's method of using extract tones but then I keep hitting roadblocks. Yes I am getting the tones extracted but then it only extracts one. I have put a loop around hoping that will fix it but nothing. I know there is something wrong with the placement of the loop I just cant figure out what. I have attached the VI in vers. 8.2
Message 11 of 15
(847 Views)
Look at attached vi and read comments.
- tbob
Inventor of the WORM Global
Message 12 of 15
(837 Views)
You were right. I needed that extra for loop. Plus I was wiring them completely wrong. Now my only issue is that I only ever get 4 tones out of it. Even when I set the threshold to 0 or -1.
Message 13 of 15
(831 Views)
In the Extract Multiple Tone Information vi, the Max Num Tones input defaults to 4.  That is why you only get 4 tones.  If you set this to -1, you will get more tones than you probably want.  If you know how many tones you expect, set this input accordingly.
- tbob
Message 14 of 15
(823 Views)
thanks tbob. thats exactly what I needed to know.
Message 15 of 15
(814 Views)
