02-06-2012 03:15 PM
Okay, I have figured out how to edit a table cell after setting a key focus. Can anyone tell me how to write the contents of my table to a text file?? Please see the attached. Thank you,
John
02-06-2012 03:52 PM
Try the "Items" property, which is a 2D array of all the strings in the multi-column list box (which is what you are using - a table is a different control). You can use "Array to Spreadsheet String" with a format of "%s" and then write that string to a text file, or wire the Items array directly to Write to Spreadsheet File.
02-06-2012 05:18 PM
Thank you, that helped! 🙂
