How do I update a network variable once created
I created a custom control to use as a network variable, but once I create it and try to modify if, the instances to not update. Also, when I create a specific type such as two strings and two buttons, it does the machine does not allow me to create a different version of the cluster with slightly different names. How can I fix this?
(2,501 Views)
Hi Steve,
In order for updates to your control to be seen in your VI, you need to save the control as either a type definition or a strict type definition. The creating custom controls link below explains what a type def is.
Creating Custom Controls, Indicators, and Type Definitions
https://zone.ni.com/reference/en-XX/help/371361H-01/lvconcepts/custom_cont_ind_type/
Using the LabVIEW Shared Variable
http://www.ni.com/white-paper/4679/en/
As far as your second question is concerned, can you be more specific as to what you mean? Could you post a screenshot of what you're trying to do, or what error you receive?
Andrew B.
Application Engineer
National Instruments.
http://www.ni.com/support
(2,456 Views)
