How do hold the peak ponits or valley?
Dear All,
I have a sampled wave, then I want detect the peak points (or valley points) and hold the point until next peak points (or valley points) appears.
Now I can use the example "Peak Detector.vi" to get the points I want.
But I don't know how to put the data to the graph. The attached picture shows the idea I want.
If you need more detail to solve my problem, plz tell me, thank you so much!!
Message 1 of 8
(3,937 Views)
hello,
i have a doubt on what you want to do :
Are you trying to operate a smith trigger function and outing signal is binary ?
or level of peaks/valley are significants and you want to hold levels as a zero order blocker ?
best regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
Message 2 of 8
(3,907 Views)
Thank you for your reply.
The input singal of DAQ is sampled from a analog singal. Not schmitt trigger.
Yes, I want to hold levels as a zero order blocker.
Do you have any suggest for me?
Thank you again.
Message 3 of 8
(3,887 Views)
i think there is a misunderstanding, i see that sampled signal is analog .
i would like to know if your green signal on graph has 2 levels , if so you,  the function you need is a smith trigger vi
Best regards
Tinnitus
Message 4 of 8
(3,872 Views)
Accepted by topic author DexterHuang
hello,
here is one way
detecting all pics index to build parts of array with each min/max value then assembling them
tell if it works
Tinnitus
Message 5 of 8
(3,851 Views)
does it suit ?
Message 6 of 8
(3,823 Views)
Sorry, this week I have some middle exam.
I will test the vi in tomorrow.
Message 7 of 8
(3,813 Views)
thank you so much~
Message 8 of 8
(3,781 Views)
