06-22-2009 04:16 PM - last edited on 07-21-2009 05:01 PM by Support
I have an Aerotech Soloist CP controller and the driver that comes with the controller uses .NET which is not supported in Labview RT so I'm trying to write one w/out using .NET. The controller is currently connected via ethernet and to a router with its own IP. I want to know how does .NET make connection via ethernet?
The Connect.vi is the one that does the connection. In the block diagram, the network constructor uses the file Aerotech.Soloist.Labview.dll which I do not have the source code for so I dont know how it work but when I run the VI, it detects the connection and returns the correct "Mapped controller name".
After figuring out how it makes a connection, then I can pass commands in ASCII directly to the controller and make a VI that will run with Labview RT. However I'm not sure if I can use the VISA write function to pass ASCII commands via ethernet?
Thank you,
Max
06-22-2009 06:17 PM
It probably uses the System.Net namespace.
All of the LabVIEW code is based on the .NET assembly that they wrote. In order for you to figure out how they make the connection you could run an ethernet sniffer like Wireshark to see what's transmitted when the "Connect" method is done. It could be anything. It could be something as simple as a TCP Open Connection, or it could be that followed by some communication. Do they have any documentation on how to communicate with the controller from something other than .NET?
06-22-2009 09:08 PM - last edited on 07-21-2009 05:02 PM by Support
Thank you for the reply.
I have tried to sniff the connection with wireshark earlier but it only give back the binary gibberish. I am new to .NET and not sure how it works entirely but it seems like the computer send the compiled commands to the controller and that's what wireshark picked up.
I have gone over the documents many times and unless I missed something, they are not very helpful. They're just the helpfiles and do not provide details on how the controller communicates with the computer.
Max.
06-23-2009 09:36 AM
06-27-2009 06:00 PM
