09-20-2024 04:30 AM
Sorry this is a lame question. I have googled it a lot, but I don't know if I'm taking things I've seen too literally and it just leaves me a bit stunned how long this doc is going to be for a pretty standard program.
What would you go with
Or
The second is easier to pass/fail individual requirements. But there’s a bunch more things that all of them should do, eg all lines get logged to file, all lines get displayed, all lines have an alarm level, and soon I’m going to have 20 requirements instead of 5 for this tiny part, and for the whole program probably 400 requirements rather than 100.
I'm trying to make my requirements docs more professional, but I don’t work in a software oriented company so I’d probably have to defend coming out with something so extremely granular... which I could stand by if I could stop doubting which one I ‘should’ do…
I don’t use teststand, maybe if I did I’d be able to see this as what’s most appropriate to plug into there.
09-20-2024 04:39 AM
Apologies that this isn't a question about the code itself so maybe belongs on another forum, this just feels like the home forum
09-20-2024 05:44 AM
I'm working with a Systems Engineer for the first time in my life. My team has never done requirements beyond "The system shall perform the acceptance test per document XYZ." Now we have a very comprehensive set of requirements in Jama. I hate Jama.
09-20-2024 06:07 AM
Version 1 is hard to misinterpret and a lot less to write, so i'd go with that.
09-20-2024 07:25 AM
Aha I'm glad you mentioned Jama. I came across something suggesting Jama today and was wondering if I should consider using it. Now I see perhaps not. What's the pain with it? One of these systems that adds more work than it saves?
09-20-2024 08:44 AM - edited 09-20-2024 08:47 AM
This topic is fascinating to me, and a thing that I now realize I haven't had to do in a long time. At a previous job I would be the one helping others with requirements writing, maybe because I was a stickler, or because I could interpret things more literal than others. I would often run through test procedures and fail things as they were written, when others would pass based on their interpretation.
As for your direct question I see no problem with either way it is written. But they will affect site or factory acceptance testing.
If you have a set of requirements where you include all sensors in one line, then to validate that one requirement you need evidence of all 5 sensors. If any one of them fail then you fail that requirement. The set of steps in your acceptance test will also need to instruct the user to do the steps for all 5 before validating the requirement.
I've also seen it written like this as an example:
1. The test software shall measure the output from the pressure input PT 112.
2. If the previously measure input frequency is not 500Hz +/- 10Hz the tester shall fail the DUT
3. If the previously measured input duty cycle is not 50% +/ -5% the tester shall fail the DUT.
4. The test software shall repeat steps 1 through 3 for PT 113, PT 114, PT 115, and PT 116, in place of PT 112.
Writing it this way is more convenient for when there are many steps taking place and then we just need to do the same steps over and over for other inputs. But from a testing perspective this can be more work to validate. Flattening these steps out over all pressure inputs is easier to test for, since each requirement is a single thing to check for. Requirement 4 here is actually a bunch of things, and may take a long time to validate, providing failing inputs for the frequency and duty cycle for so many sensors. Then again you can maybe convince the customer that looking at the report, and seeing the limits used is enough to validate lines 2 and 3, and all this really needs to prove is it is capable of measuring individual readings. In which case the requirement could be checked in a variety of other ways, like measuring the output with a scope, and then seeing that the tester has the same value in the report.
I have also seen a weird situation where the Requirement 4 actually said "The test software should repeat..." which is a bit weird. A shall statement needs to be done, and proven that it is done through verification. A should statement I believe means the software needs to do it, but there is no requirement to verify it does it. That would mean we need to prove it worked for PT 112, but for all others we just trusted the tester did what it should have.
Basically every Shall statement means lots of extra work. You need to writing the test procedure, then for every time the test procedure is ran the operator has lots of extra work to document it. Then this is repeated for factory acceptance test (FAT) and a site acceptance test (SAT). So you should limit your Shall statements to things you really do mean need to be proved it is doing. In this example there might be another requirement that the pressure sensor should output a 5V signal. This is a thing we can put in there but doesn't need to be verified. Then again maybe the customer doesn't care what the sensor is at all, just that the system can measure pressure within some tolerance. If that is the case maybe we can don't care about the signal type at all and can plug in a dummy pressure sensor and just see that the value goes bad when we expect, and that a golden DUT passes as we expect.
There's so much room for interpretation in the intent, and how to prove a thing does what it needs to. You can spend a ton of extra time proving the most simple thing, or go in circles forever because of a badly written requirement. My main advice is to think about how you will test for your Shalls when you write them. I remember one common requirement I struggled with was:
The test software shall be written in LabVIEW 2020.
Seems fine on its surface but when I have a built application how can I prove that? I can look at what runtime engine Windows has loaded when I run but now applications can run in different runtime engines. I can open up the EXE in a hex editor and try to find it there, but that can be unreliable. And in the end this is more of a design requirement and I'd suggest making it a should statement.
EDIT: Oh and NI still has their Requirements Gateway software. You have it scan for requirements in documents, then it can scan the source of LabVIEW or TestStand for where those requirements are being fulfilled, and then have it scan the SAT and FAT documents to see where they are being covered. It is a bit clunky at times, but it is great for checking for testing coverage.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
09-20-2024 09:16 AM
Jama is probably great. I'm just not accustomed to working with formal requirements.
09-20-2024 09:34 AM - edited 09-20-2024 09:35 AM
Good point on the single line, you can add that the measurements should be tested individually, so basically a 1a-1f
I prefer requirements written from what they Should do, not what it shouldn't do. Also, you're already (pseudo)programming, let the programmer decide in which order (or in parallell) to test it.
