How i can get the needed information (for example value of string constants) from the VI file by open it for read in a automatical way?
1. I have many VIs with string constants.
2. Every string constant holds vaule (for example "GPIB::11:MASK ON" or "SWITCH::POWER DIS")
3. I do not want to open all of files (about 2000 files) and in manual way explore the constants'values
4. I want with some VI or perhaps tool list the directory that will include all of 2000 VIs and to get some LOG / RESULT file with values of those constants
The questions:
1. Does it possible at alll???
2. What is the format of VI file? Does it open?
3. Any hints how i can do it? Any suggestions? Proposals??
Thank you very much,
                                     Yuri
Thank you & Best Regards
*I use LabVIEW 2018 & TestStand 2021 versions
Message 1 of 14
(3,084 Views)
I have not simple soluce but only a crazy idea Smiley Tongue:
Export VI as VI Strings (VI Method) then search for each text file the corresponding info such as :
<BDCONTENT>
<CONTROL ID=81 type="String Constant" >
  <DESC></DESC>
  <TIP></TIP>
  <PARTS>
   <PART ID=11 order=0 type="Text"><LABEL><STEXT>TEST</STEXT></LABEL></PART>
  </PARTS>
  <DEFAULT><SAME_AS_LABEL></DEFAULT>
 </CONTROL>
but I recognize it's long & delicate to develop it, surely very long in execution time...
It's only to help but I hope there exists a better way 😉
Message Edité par J.DECHET le 01-13-2010 12:45 PM
Message 2 of 14
(3,063 Views)
If i can export VI like STRINGS so i will can parse it!
Great idea! I did not know that we can represent VI like a STRING/XML format!
I will try it now!
Thank you alot!!!
Message 3 of 14
(3,060 Views)
tried   not working.  anybody able to ?
Message 4 of 14
(3,057 Views)
Don't forget to specify TRUE as Export Diagram...
In fact, I used this method in the past to know in which version of LabVIEW was written a VI (first line of text file). I didn't find other method at this time...
But I prevent it's a very slow process and with your 2000 VIs you risk to wait a serious time.
Message 5 of 14
(3,052 Views)
Not so slow, i will LIST the directory and after it iteratively will send every file to CONVERTION without manual work 🙂
p.s. i suppose so ... 🙂
Message 6 of 14
(3,050 Views)
Ok, it's true that today, computer's technologies are faster than when I practised it (one processor with slow hard disk, only 4 years ago)...
Message 7 of 14
(3,046 Views)
Question regards conversion:
I need instead REFERENCE to present file to find way how i can give a REFNUM of any OPENED file (such as i can iteratively to give the list of the files .. and not to
    manually seed it to every file...)
Any idea??? How i can do it?
Please see the attached picture of the issue
Thank you all!
Message 8 of 14
(3,009 Views)
Use 'Open VI Reference' in the palette named "Application Control" instead of 'Open File' and don't forget to close it after... 😉
Message 9 of 14
(3,004 Views)
Hm i did it but now other program? Could you please the attached picture why it happens?
Thank you alot!
Message 10 of 14
(2,999 Views)
