05-02-2010 11:02 PM
05-02-2010 11:43 PM
hi ganesh kumar,
If you have a provision to check whether an USB port is busy or not in your local PC,then you can share that particular status information(may be the data type will be a boolean) using TCP/ip vis...That means you can monitor that particular variable from other pc using tcp/ip vis where that variable will give the status information of the USB port..
Thanks and regards,
srikrishnaNF
05-03-2010 12:06 AM
05-03-2010 12:14 AM
hi ganesh kumar,
JUst answer my question,say your hardware is connectd to your PC,can you get the details of the hardware using labview including hardware name?
If your answer is yes...then you can access those details from other pc using TCP/ip vis..
Thanks and regards,
srikrishnaNF
05-03-2010 01:12 AM
I have no idea how to access the USB device through labVIEW. Itries to use VISA functions but I can't.
05-03-2010 01:27 AM
hi ganesh,
Try this link...http://zone.ni.com/devzone/cda/tut/p/id/4478
Do your device/hardware has any SDK?
T hanks and regards,
srikrishnaNF
05-03-2010 02:30 AM
