How to add control or indicator at runtime?
Hello everybody,
Do you know how to add control or indicator at run-time? I'm using LV 8.2.
Thank you.
Message 1 of 11
(4,072 Views)
Hi yoppy,
you cannot add controls at runtime. Point.
But you can:
- make predefined controls visible (by property node)
- move predefined controls to visible pane (by property node)
- use arrays of controls
- use a fixed amount of controls, but assign their values to different "storages" aka "variables"
Message 2 of 11
(4,062 Views)
You can check for the example at this link.
You can dynamically create controls (which you pre-defined) and assign them to the parameters you are interested in.
I will attach the sample code.....check it out.
-FraggerFox!
Certified LabVIEW Architect, Certified TestStand Developer
"What you think today is what you live tomorrow"
Message 3 of 11
(4,055 Views)
@Fragger Fox: Thanks for your code. But unfortunately, it's in LV ver 9.1. Mine is 8.2. Would you please convert it?
Thanks in advance.
Message 4 of 11
(4,049 Views)
Here you go...
-FraggerFox!
Message 5 of 11
(4,040 Views)
The interesting part is to get values from the newly created controls.
Jim
Message 6 of 11
(4,032 Views)
That's not really dynamically creating controls. It's simply opening VIs and moving them so the window relationship is set through the Windows API. For one thing, it's not portable, as it's Windows-only. Also, the control has no relationship to the "parent" VI.
Message 7 of 11
(4,012 Views)
I did this with a picture control.  It's in LV 8.2.
Jim
Message 8 of 11
(4,004 Views)
Thank you Fragger Fox abundantly.. I wonder how I can set and get values from the created controls.For example, I type on String control, and I want to catch the value on the string control.
Also, can I create more than one same controls, for example 3 controls of string.
Thank you.
Message 9 of 11
(3,983 Views)
Yes, you can create multiple controls. You can make the control VIs re-entrant and launch multiple controls
-FraggerFox!
Message 10 of 11
(3,972 Views)
