How to browse and update a file in html by using labview?
Hello,guys,I am a newcome here.I have a trouble  to handle just as the title,please give me some directions,THX!
Message 1 of 10
(3,154 Views)
So what do you want to update in html?
CLD Using LabVIEW since 2013
Message 2 of 10
(3,142 Views)
A *.bin file.
Message 3 of 10
(3,139 Views)
So you want to update the location or name of a *.bin file in html?
Message 4 of 10
(3,135 Views)
OK,yes,in fact ,its name is FW.BIN.Is it important?
Message 5 of 10
(3,131 Views)
I still struggle to understand what you want to do! So please explain a bit more.
Rolf Kalbermatter
My Blog
Message 6 of 10
(3,129 Views)
I  am sorry for my bad express.I just want to finish the following process:
1、browse the file,what is called fw.bin;
2、submit the form using the update button.
Message 7 of 10
(3,123 Views)
you need to upload your html file so that we can better uderstand.
Message 8 of 10
(3,122 Views)
Accepted by david_cow
Most likely your device expects a HTTP Post (or maybe HTTP Put) command with the binary file as contents. You can create a HTTP Post transaction with the HTTP Client library in LabVIEW.
What you need to find out is the url that the device expects for the upload. That can be retrieved from the HTML file that you see in your browser by looking what url and command is used to post the file when you click your upload button.
A more automated way would first use a HTTP Get to retrieve your firmware update page on the device, then parse the returned HTML string for the relevant url and command and then issue the HTTP Put or HTTP Post with your firmware file.
Rolf Kalbermatter
My Blog
Message 9 of 10
(3,115 Views)
Thank you very much!
Message 10 of 10
(3,100 Views)
