How to change many instances of diagram constant in different vi's?
There is a diagram constant that appears in many vi's within a large legacy project. The constant is set to Value1 everywhere. Previously I learned if I want to set it to Value2 instead, I need to change it manually by editing the vi. My plan is to search each vi for this constant, and make the change. But is there a smarter way, or another approach to consider when I write code myself in the future? (Presently a beginner but trying to learn).
Message 1 of 14
(2,157 Views)
If the constant should not be a constant you need to find a different solution. For example you could read the desired value from an ini file and put it in a global (plain global or state machine), then read that value wherever needed.
It really depends on a lot if things. Maybe it should be a control input for all subVIs so you can change it even during the run.
Message 2 of 14
(2,153 Views)
This is a more subtle version of using duplicate code in different places, then trying to find each instance and making the same change to all of them.  In this case, these are duplicate constants that you need to change.
To avoid this in the future, have the value in one place where all the different VIs can access it and you only need to change it in one place.  This is one of the few times where a global variable is appropriate.  There are many other ways to skin this cat as well.
Bill
CLD
(Mid-Level minion.)
Message 3 of 14
(2,143 Views)
Accepted by colorimeter
What I would do is create a VI containing constant wired to indicator. Now use this VI at all places where you use the constant. Now when you want to update the value of the constant, go inside this single VI and update it, every instance of this VI will be updated to the new value.
You can set the VI to inline for best performance.
Santhosh
Soliton Technologies
Message 4 of 14
(2,112 Views)
Does this execute faster than wiring a global variable?  Does inlining the subVI make it just as fast as if it were placed directly in the VI since it's part of the VI now?  Is it more memory efficient?  Is it just a preference to avoid global variables?  Seems to me that a global would just reference a memory location while the subVI is extra code.  Just asking so maybe I can take advantage of a different way of doing things.
Bill
CLD
(Mid-Level minion.)
Message 5 of 14
(2,077 Views)
I like putting some constants in VIs because they cannot be written to during runtime. With a global, there is a chance someone unfamiliar with the code will try to write to it.
When I use a VI for a constant, it's usually for something that I think won't change. For example if a section of the code is dealing with a stage, I might call that module "Stage" and put that string constant in a VI. Then I can use it for logging data or errors and know it has to do with the stage module. But, later on we might have to add a second stage to the system, so I change that "Stage" string to something more descriptive.
Message 6 of 14
(2,036 Views)
I have not done any benchmarking against Global variables, but by default, I seldom use Globals. Moreover, there is no control if some developer opts to writes data to a Global Variable that was meant to be a constant (and you've to write the constant value to global at some place).
In theory and my understanding is that inlining the VI will make the content of the VI become part of the caller which is as if the constant was directly placed in the caller VI and compiled. This way, it will always be faster than reading from memory as the constant is already part of compiled code.
I extensively use this technique which is similar to the const keyword of C programming, to use the same constant across VIs similar to how you typedef ENUM to be used across all callers.
Santhosh
Message 7 of 14
(2,023 Views)
That's the second time I've read about being afraid that users would change the values.  Why would the global ever be exposed to a user in the first place?  Unless you are letting the technicians run source code, which would never, ever be allowed where I work.  I would be more concerned about someone changing the source code than changing some global values.  On the other hand, with globals, it is very easy to make the jump from tweaking values in a global to reading from a config file into those globals.
Now inlining does make sense because, as you said, it becomes part of the VI itself.  I guess this results in constant folding?
Bill
CLD
(Mid-Level minion.)
Message 8 of 14
(2,013 Views)
A typical scenario for using the VI based constant will be mostly in the source code where the end-user need not change or require changes after building them. In my line of work, we use source code extensively and engineers use the test automation, in this case, it is fine to edit the VI instead of having a file read/write feature.
If the requirement is to store settings, it is not a constant and cannot use the VI based constant, instead, it will turn into an LV2 Global VI to store the settings.
Santhosh
Message 9 of 14
(1,995 Views)
Oh, so different usage cases.  The software I write is strictly for production use and it is forbidden to change anything.  Using FGV in the manner described above just makes it an extremely slow global.  But if you actually meant "AE" where actual calculations go on and you need to make sure they complete before anything else asks for the data - that's different.
Bill
CLD
(Mid-Level minion.)
Message 10 of 14
(1,990 Views)
