How to communicate to an I2C device
Hi Sir,
I have an i2c interface temperature sensor, I try to use labview to read the value.
I buy a usb-to-i2c tool, after installing the driver, i can only find it in "Computer managment":
But i cannot find it in NI-Max.
Anyone have this kind of experience to handle it ?
Thanks.
Learning from other people
Message 1 of 15
(5,044 Views)
Accepted by Brzhou
Please share more information on your Temperature sensor board with the USB to I2C tool - links to user guide/manual or model number and possibly some photos.
Typically, these USB to xx protocol chips show up as a VCOM (virtual COM) port and you use VISA libraries to communicate to these USB to xx protocol chips. In some cases, such as the FTDI chips, there are special driver DLL provided by the manufacturer and you call these DLL in LabVIEW to communicate with the USB chip which in turn based on the commands you send will translate into respective protocol commands (like I2C in your case). All these are manufacturer and chip dependent and hence need exact details to guide you.
Santhosh
Soliton Technologies
Message 2 of 15
(5,025 Views)
Hi Sir,
For i2c chip:
For usb to i2c tool, use CH341 series:
So you mean normally, if we choose the right usb-to-i2c tool and driver, we can see it in NI-Max ?
Any recomendation for this tool ?
Thanks.
Message 3 of 15
(5,011 Views)
Well, you will never see the I2C device itself in NI-Max.
You will only see the Virtual Com port your USB to I2C is using.
=== Engineer Ambiguously ===
Message 4 of 15
(4,966 Views)
NI has its own I²C/SPI Interface Device, USB-8452. It comes with native LabVIEW support.
Control Lead | Intelline Inc
Message 5 of 15
(4,929 Views)
@Brzhou wrote:
Hi Sir,
For i2c chip:
Thanks.
Yes, the choice of the right USB-to-I2C tool will make your life easy.
I would suggest USB-8452 due to its native drivers for LabVIEW
Santhosh
Message 6 of 15
(4,922 Views)
Thanks, i will check this device in website.
Message 7 of 15
(4,916 Views)
But i guess usb8452 is costly, any cheap solutions ?
Thanks.
Message 8 of 15
(4,915 Views)
I see, thanks Sir.
Message 9 of 15
(4,914 Views)
Thanks.
There are of course cheap solutions, then you will spend engineering time in developing code to automate it and debug hardware issues. Considering the engineering cost to get it up and running, it would be wise to get off the shelf solution that is proven to work.
This seems to be cheap option - https://www.adafruit.com/product/2264?gclid=EAIaIQobChMI-5fip7y3_QIVcQNlCh0GbgnVEAQYASABEgIB9PD_BwE
Now you've to look for LabVIEW drivers for FT232H with wrappers for I2C functionality, if not available, you could develop your own and debug it to working state.
Santhosh
Message 10 of 15
(4,898 Views)
