05-26-2004 05:30 AM
05-26-2004 07:00 AM
03-08-2012 11:59 AM
@sattu wrote:
Hi all ,I want to convert audio speech say"I love you" now I want to write this speech on a text file ?
I want answer with reference to speech recognition plz help me.
Thanks in Advance.
I down-loaded Express Scribe from NCH (u need speech recognition already set up -USE ID 0) -options, speech-to-text. I used a sync folder (read the help from the program) the program will down-load whatever additional software it needs (e.g.. ffmp3 if you are using MP3 format). I used conversion software and output to the sync folder (the program automatically detects (or click the synch button) then will convert the speech (speech-to-text in notes section) I let it run overnight (7 hours) it completed all 10 (each 1 hour long) class lectures. The text is not perfect but it is easier to change or delete the parts I don't need for lecture notes.
07-23-2013 09:06 PM
