How to create a boolean that when it's ON, it's on for an iteration then switches back off
Hello everyone,
I couldn't explain it well in the title, but I'm trying to control a device that only wants a single click to switch. For manual operation, a latched switch like OK button would do, but I'm trying to automate it.
For an example, if we have a numeric control, and a "Equal to?" boolean connected to it with an indicator. e.g (If number is = 10 then TRUE) The indicator would stay ON until that number changes.
But when I'm trying to get is, the indicator switches on for iteration then off. Plus, when I change the number to something is, I want the indicator to also switch on then off.
If this is solved, it would help make the device receive a SWITCH signal to turn on once an option #1 is selected, and when I change the option it will receive another SWITCH to switch option #1 off.
Your help is much appreciated!
(2,896 Views)
Accepted by malmureeh
Hi malmureeh,
you want to detect edges of a boolean signal, like rising edges.
There's a ready-to-use function available: BooleanCrossing!
(2,890 Views)
Hi Malmureeh,
My name is Jonathan & I work within the Applications Engineering Department at NI in the UK. From your post I interperate that you want an LED to flash at a specific iteration?
Below is some code you could try to implement yourself:
I hope this helps & let me know how you get on.
Cheers
J
(2,879 Views)
@GerdW wrote:
Hi malmureeh,
Hi GerdW,
Thanks alot for your fast response and help! This is exactly what I've been looking for! Smiley Happy
I wondered why this function isn't available since it would be essential in some fields, but foruntately it is available!
I've attached the program that I tested Boolean Crossing on.
malmureeh
(2,874 Views)
@JCH_26 wrote:
Hi Malmureeh,
Cheers
J
Hi JCH_26,
Thanks for your help! But this wasn't what I was aiming for. The problem has been solved.
I appreciate your quick response! Smiley Happy
malmureeh
(2,871 Views)
