05-14-2012 03:30 AM
How does one create an array of colors? Is this similar to creating an array of strings or an array of numbers?
How would one create a color constant? For example, for my XY Graph, I went to create -> property node -> BG Color,
and changed this to write. But now I need to wire a "color constant" to this property. I don't know how to do that.
05-14-2012 03:58 AM
Yes creating a color constant is similar to the String and numeric array Just pull a color constant and place it inside an array. Just take a color constant and wire it what is the problem?
05-14-2012 03:58 AM
On your front panel, drop an array control.
From the numeric pallette, drop a framed colour box control.
Drag the colour box into the array.
On the block diagram, right click the array and change to constant.
05-14-2012 04:02 AM
Yes.
murchak wrote:How would one create a color constant?
The color box constant has been moved around into different palettes over the years so only real expert know how to find it
But you could also use "QuickDrop" to find it 😉
In LV 2010 here's where to find the color box contant :
And in the control palette, you find the color box in the "numeric" subpalette.
In terms of data type, the is no "color" data type, it's a U32, that's why when you create a constant or control or indicator from the node BG color you get a numeric, there might be an idea to change that in the LabVIEW Idea Exchange, I'm not sure...
Hope this help
Epictetus
05-14-2012 04:10 AM
So that's where it is on the block diagrams!! I could never find it. Whereas I knew it was a numeric on the front panel.
That's even easier then.
05-14-2012 04:11 AM
Ha.. One more tip you can search for the color constant in the search option instead of posting in the Forum 😄
05-14-2012 04:13 AM
P Anand wrote:Ha.. One more tip you can search for the color constant in the search option instead of posting in the Forum 😄
Yes but he wouldn't get all the useful tips if he did a search
Epictetus
05-14-2012 04:15 AM
Ya I know he can't search for a solution there but atleast he can get the color constant.
05-14-2012 04:54 AM - edited 05-14-2012 04:55 AM
Thank you to all that replied and helped me with this.
Anand,
Thanks for the tip. I will try to remember to search for things in the LabVIEW help documents first. The fact that I didn't, highlights the difference between a novice and an expert.
I used to tutor students in physics and I always wondered why they didn't try this or that, then one day I realized that they were simply not familiar enough with the subject matter
to independently think of all the little things that I would think about first when tackling a physics problem. They simply were not experienced enough to reach for a standard bag
of tricks, and always sought help from a TA first. Experience is a great thing indeed.
05-14-2012 05:01 AM
Yes True. Also LV help has improved a lot more in 2011 version. Just tried to make life easy. Good luck
