How to deploy a VI to cRIO memory programmatically?
Dear all,
I would like to use the Remote panel (of LabVIEW) to control a VI under the cRIO from a client PC without the LabVIEW development system. I am thinking to build an exe file with the code inside can execute the Remote panel  programmatically. But the issue is that the VI is not loaded in the memory of cRIO. I tried 2 following methods:
1. I tried to deploy a VI to cRIO by WebDAV and put the VI to /home/lvuser/natinst/bin/ but it was failed as below.
2. Then I tried to load/execute the VI under cRIO via VI server but it was failed also.
ref: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIE4CAO&l=en-VN
3. I don't know if there is any methods to deploy a VI into the memory of cRIO programmaticallly as the Deploy action in the Project explorer.
Please help me to explain why I get the error in 2. and give me some possible methods for 3.
Thank you in advance.
(1,105 Views)
Accepted by anhduy92
You need to build and deploy your VI as a startup rtexe. See Configuring Remote Front Panels on a Real-Time Target
(1,061 Views)
How about more than 1 VI I would like to remote panel?
(1,024 Views)
Why would you want to remote more than 1 VI?
There is only one rtexe running on a cRIO at a time. As a matter of fact, rtexe is designed to run without any front panel. Interaction with the front panel might introduce jitters to the system and impact the performance.
If you want to interact with the rtexe from the host PC, the best way is to create a separate host UI that communicates with the RT VI via shared variables or network streams.
See Understanding Communication Options Between the Windows HMI, RT Processor, and FPGA
(1,009 Views)
I understood. I just ask for some further use. Thank you for you support.
(960 Views)
