How to disable the "Load Warning Summary" dialog box in LabVIEW?
Hello everyone,
I'd like to disable the "Load Warning Summary" dialog box in LabVIEW (from LV 2009).
This dialog box appears when you try to load a VI marked as a warning by LabVIEW.
(see the joint image file)
No option in the Tools >> Options dialog box is available to do that.
Do you have some solution?
Thank you,
Jeremy
Message 1 of 8
(3,630 Views)
Hi Jeremy,
the warning box will/should go away after saving the VI... Have you tried to save the VI in it's apparently new context?
Message 2 of 8
(3,628 Views)
Hi GerdW,
The fact is that the dialog box always shows up when you open/load the VI (at the end of the conflict resolution process).
If you have a lot of conflicted VIs to load, you will obtain the same amount of dialog boxes... which is a little annoying.
So how can I save the VI before trying opening it? (I use a Project file window)
Jeremy
Message 3 of 8
(3,625 Views)
Hi Jeremy,
you have to save all VIs after loading the project...
As you already resolve conflicts: why do they happen? Do you often copy VIs from one location to the next?
Message 4 of 8
(3,623 Views)
GerdW,
You cannot save conflicted VIs after loading the project, as they are marked as warning...
You have to open them before in order to resolve conflicts, and after that, the mentioned dialog box appears, before any saving is possible.
Conflicts happened as I move the library file which contains these VIs.
Jeremy
Message 5 of 8
(3,609 Views)
Hi Jeremy,
why do you move the library?
You can resolve conflicts without opening the VIs: right-click the marked Vis and select the menu entry "resolve conflicts"...
Message 6 of 8
(3,607 Views)
GerdW,
I'm sorry but the menu entry "resolve conflicts" does not appear in the context menu when tou right-click a marked VI.
It appears when you right-click the library file.
Jeremy
Message 7 of 8
(3,602 Views)
Hi Jedjed,
The best is to handle the warning source.
Then, did you try to disable the automatic error handling and the debugging  after opening the conflictual VI? (see picture).
Sincerely
Romain DUVAL || RF & Semiconductor Staff System Engineer || CLA || CTA
National Instruments France
Message 8 of 8
(3,564 Views)
