How to do vertical alignment for two graph at the left ?
Hi All,
The position of left side of the graphs would be updated automatically when Yscales updates. how to make them fixed or could be aligned at the left?
Please find the picture attached.
It seems I could not  seperate the two plots to two screen in mixed sinal graph. the waveform chart with stack plots are very close to what I want, but I can't update the x axis. do you have other suggestion?
Thanks.
Message 1 of 11
(1,828 Views)
Hi yeah,
Use just one XYGraph/WaveformGraph with two Y scales for both plots…
Message 2 of 11
(1,823 Views)
Hi Grewd,
Thanks. But how I can I have the view such as stack plots?  The data may be 1pA or 1M ohm.
Message 3 of 11
(1,818 Views)
Hi yeah,
By setting the Y axis ranges as needed…
Message 4 of 11
(1,806 Views)
Hi Gerdw,
I'm not quite understand by setting the range, is that means I have to know the range of the data and disable autoscale?but I do hope to keep the autoscale function.
Message 5 of 11
(1,798 Views)
Hi yeah,
Well, yes.
Then you can set both Y axes as needed to simulate a "stacked" behaviour: one plot will occupy the upper half of the plot area, the other the lower half…
That's the reason you ran into this problem…
Message 6 of 11
(1,790 Views)
Hi Gerdw,
Thanks for the instruction. I was thinking if I could make the label name area fixed even if I reserve enough space for the autoscale actions.
Message 7 of 11
(1,783 Views)
Accepted by yeah
@yeah wrote:
Hi Gerdw,
Right-click the graph area -> Advanced -> uncheck "Auto Adjust Scales".
Message 8 of 11
(1,765 Views)
Exactly! I do that always for all my graphs.
In addition, make sure that the marker format is reasonable. For example you could scale the upper graph in pico-Ohms or even use an SI format.
Also, do you really (really???) need six decimal digits for the x axis????
Message 9 of 11
(1,741 Views)
Thanks, it is working.
Message 10 of 11
(1,712 Views)
