How to edit an objects propertys from another VI
Hi, I am running my main vi. I have a preferences.vi window that opens.
The preferenecs.vi opens using an invoke node.
the preferences.vi needs to be able to fill up the menu items for a Ring control that lives in the main.vi
Normally I would you a property node, but as this object is in a different vi how do I communicate with it.
I realise that a global variable only seems to be able to pass values between object, and not change the behavoiur of objects.
Can any one help please!
Many thanks, Alec
(2,739 Views)
Alec
Right-click on the Ring control on the main.vi Fp and create a reference.  Pass this reference to the preferences.vi.  Use property nodes to set the attributes of the Ring.ctl on the main.vi
Visualize the Solution
CLA
LabVIEW, LabVIEW FPGA
(2,726 Views)
Accepted by alecjcook
It should look like this.
Tim
GHSP
(2,723 Views)
