How to enable and disable elements in a Enum control
I have two  enum control for a value change event in one enum control i want to hide or diasable some elements in other enum control .
Message 1 of 8
(7,765 Views)
You use the DisabledItems[] property. The input is an array and you pass it the index of the elements you want disabled.
Message 2 of 8
(7,761 Views)
maybe you can use the disabled Items[] property
dennis beat me to it.....
Message Edited by Harold Timmis on 08-25-2009 03:20 PM
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 3 of 8
(7,760 Views)
how to enable for disabling i am passing array with indexes i want to disable for enable what should i do.
Message 4 of 8
(7,745 Views)
To enable, you pass an empty array.
Message 5 of 8
(7,738 Views)
Accepted by srinivas
Thank you i got it.
Message 6 of 8
(7,730 Views)
Then please mark Dennis' reply as the solution to your question rather than your own thank you message.  You can unmark your message as the solution by going to the options menu to the upper right of your reply.
Message 7 of 8
(7,709 Views)
Dennis, thanks for your answer.
Message 8 of 8
(6,044 Views)
