How to find the maxima of Y and its corresponding X value in XY graph.
I am new in this field. I am getting a problem regarding to my vi and I need help.  I have read the excel data sheet in the block diagram and smoothed the X and Y values by SG filater. So my problem starts from here-
1. First I want to take derivatives of Y with respect to X . For this purpose I used the derivative function but I am not sure whether this is correct or not.
2. Next I want to plot the derivative of Y with respect to X and to find the X value for the maxima of dY/dX.
Any help will be appreciated.
Thanks-
Message 1 of 9
(5,124 Views)
Thanks-
can you provide exact requirement on whats your input and what is your expected output "Title and contents seems mismatching"
Message 2 of 9
(5,121 Views)
use this sorting vi so that u can get the maximum of one value with respect to the other.......
There are  two ways to tell s thanks in forums : either give Kudos or  Marked Solutions
Message 3 of 9
(5,112 Views)
My inputs are voltage (V) and current (I) data which is in a excel spreadsheet  and my required output is the value of voltage corresponding the maxima (as shown in the picture below) of the first derivative of current with respect to the voltage (dI/dV).
Message 4 of 9
(5,106 Views)
are you trying to sort using some order (maximum to minimum) or trying to find the elemnt with maximum value in an array?
Message 5 of 9
(5,103 Views)
use this vi... or else share excel data i will make a entire vi for ur case
Message 6 of 9
(5,100 Views)
i will sort and find maxima or minima
Message 7 of 9
(5,091 Views)
Accepted by bdcpp08
If my understanding is correct you can do this simple methods
From the 2D Array Extract dI/dv and Voltage Value
USe Array Min Max Function and Get the Index of Maximum value for dI/dt and use the same index in voltage array which will give you the maximum voltage value
Message 8 of 9
(5,086 Views)
ya this will also help you....
Message 9 of 9
(5,082 Views)
