12-12-2024 07:57 AM
I am using a decoration box in my front panel, I want to fix that box with tab, so that user can't move it or drag it. Is there a way to do that?
Faizan Habib
12-12-2024 08:07 AM
Hi Faizan,
I don't understand your problem: why/how should a user be able to "move or drag" a decoration on your front panel of your executable???
12-12-2024 08:36 AM
So, you can see in below screen shots, the background box is moveable, I want to fix it so that user can't even select it when put cursor on the box, user should only access the controls.
12-12-2024 08:44 AM
Hi Faizan,
You can group front panel elements…
Still the question is: why do your users have access to VI front panels in edit mode?
12-12-2024 09:19 AM
You can lock any front panel object, even decorations.
12-12-2024 09:27 AM - edited 12-12-2024 09:30 AM
You can "lock" everything on the panel like Basjong53 has shown, but your end user can simply "unlock" them.
GerdW has an extremely valid question that I will rephrase.
Why are your end users running programs from the LabVIEW development environment?
This issue will not exist if you are compiling your LabVIEW program into a Windows executable and distributing that to your end user.
BTW: You are free to distribute and even charge money for executables, no further licencing is required.
12-12-2024 09:33 AM
So, right now the project is in debugging stage, here the user means me and my colleagues.
12-12-2024 10:54 AM
Actually you can lock things individually here is an example
