How to identify communication problem between DMM4040 and my PC in labview program.
  I have DMM4040 and am using Labview2010 version..I have the DMM to connected to my pc, and while running the program if i lost the communication between the DMM and my pc, how can i recognize and solve it..
  I need to display a error pop up message if there is no communication, so that i can stop my program from running.
'' A professional is someone who can do his best work when he doesn't feel like it''...........
(2,416 Views)
Surely you are using the error in/error out connections?
(2,400 Views)
Yes am using..
(2,380 Views)
You can use timeout to check whether communication is happening or not? When timeout occures then you can say error.
One more thing, I dont know your application but if possible when first time timeout occured then try one or two more time before you say error in communication.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,375 Views)
